Engine numbers - Chevrolet Forum - Chevy Enthusiasts Forums
Engine numbers
February 29th, 2008, 7:27 PM   #1
Engine numbers
Hi, I need help findingsome Info on my motor, Just bought a nova and all they said was it was a 350, The numbers on the back said 39700198 i think the last number was an 8 or 9 or maybe 0 couldnt really get down on it to see, then the front said vo62lchc 186305817 please help me out with any info thanks
March 1st, 2008, 9:35 AM   #2
RE: Engine numbers
I saw several 39700-- block casting numbers. I didn't see the actual number you listed. Mortec.com has some CSB casting numbers.
I wanted to add, the only CSBblock to have the oil pressure takeoff drilled and tapped at the front of the block is the four-bolt 350. The location is above the timing cover, slightly toward the passenger side.
This other stuff is just general chevy small block, not just 350. If the block has an 8 inch balancer, it was used on trucks and high performance applications. The oil filler pipe in front of the intake manifold was used until 1968. This info came from a chevy small block ID guide. I don't know how accurate?
March 1st, 2008, 6:10 PM   #3
RE: Engine numbers
The number on the back is 3790010, and the numbers on the front are vo6212chc-18s305817
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
