Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
help with 454 block and 427 rotating assembly
Old March 22nd, 2015, 7:58 PM
lownslow's Avatar
Default help with 454 block and 427 rotating assembly
I'm looking to do a 427 crank shaft with 427 pistons inside a 454 block! I understand that the bores and the strokes between the two and everything I just need help determining what size dome piston to run and what CC head to run..i want to run an open chambered head and have about 10:1 compression ratio..help would be appreciated!
Bands of good cams guys like to run (been looking at voodoo or crane) other input!
Budget is right about $10,000
Maylon 88 camaro
Camaro
April 10th, 2015 4:25 AM
Bar4em
April 15th, 2014 8:29 PM
Redlines4life
January 12th, 2013 10:37 PM
91vette396
August 9th, 2012 8:53 PM
cowboyfromhell
June 3rd, 2007 5:31 PM
Quick Reply: help with 454 block and 427 rotating assembly
