Engine Building & Overhauling All you ever wanted to know about building and rebuilding engines in here! Remember to post your model-specific questions in the correct section.
looking for a little more power out of my tbi.
Old March 25th, 2012, 12:20 PM
downen's Avatar
Default looking for a little more power out of my tbi.
i have a 1995 chevy 1500. it has a 350 tbi and a 350 turbo tranny. im looking to get a little more power out of it. everything is stock that i know of. any help would be geat thanks.
Old March 25th, 2012, 2:58 PM
2wd-K5's Avatar
simplest things would be exhaust, headers and cold air intake.
if u live in a non emissions area, u could gut the cat (but i cant recomend it
Old March 29th, 2012, 5:51 PM
downen's Avatar
Default still no power
okay i have those things. my main problem is i have absolutely no low end power i really need some advice on this. exhaust, headers and cold air intake really made a difference but it still wont hardly turn a tire.
Old April 22nd, 2012, 4:35 PM
2wd-K5's Avatar
pill off the TBI, buy a rebuild kit, and go to work with an air die grinder and a carbide bit, smooth out all the imperfections and just do a general cleanup on it, do not remove the throttle blades as they are hard to set back up this usually give better throttle response, shotr of dropping in a cam and buying a chip, this is your best bet
Old May 12th, 2012, 1:02 AM
bosanjo's Avatar
You could just get a higher stall torque converter and that way you can use more of your upper band. Also, might have a problem with your gearing being inadequate. You could increase the ratio to get into your power band quicker.
Old May 13th, 2012, 7:02 PM
downen's Avatar
Default different motor
i went a different direction and put in a rebuilt 73 sbc 350 my tbi unit ended up being a 305. problem is i dont know how to hook up the distributor or anything never done much with carbs so if anyone could tell me what i have to swap out and how to hook everything up it would be great thanks
Old May 14th, 2012, 3:51 PM
bosanjo's Avatar
Honestly, the best way to figure this out would be to have someone who has done it before show you or look up videos on youtube so that instead of trying to figure out what someone is talking about you can see it and learn it visually. It helped me a lot. It's not hard to attach the top end to a 350. I did it and I'm a dolt.
Old May 14th, 2012, 8:37 PM
RacerX's Avatar
If everything is stock then you dont have a TH350. Maybe if this was some underperformer mid size Nova from the mid-70s, but for a 1995 this has a 4L60-E transmission.
Since this motor is a rebuilt one from 1973, let me ask you if you replaced the camshaft. Weak camshaft gives weak thrust. 1973 was the 1st year for emission controls and last year for leaded fuel, so they normally came with limp cams, seriously detuned and lower compression ratios. Would have been easier to modify the original engine especially considering the pollution control devices. Look in the high performance daily driver side of JEGS. They make a nice camshaft for tow vehicles which gives plenty of low-rpm power. And mate that with a rear-end under 4.10 and you should be able to peel off strongly.
Old May 15th, 2012, 8:08 PM
downen's Avatar
i put the turbo 350 in it the other transmission was bad. i will def. look up the cam though thanks for that. anyone have any head sugestions i have heard 305 heads will give low end torque but need to be atleast 68cc or compression will be to high. so if anyone can point me in a good direction on the heads that would be great thanks
Old May 17th, 2012, 6:44 PM
downen's Avatar
this is the carb i have for my motor any info on it? 7043202 4 barrel quadrajet
Kishvier
June 30th, 2012 12:40 AM
Like_A_Rock
January 13th, 2011 1:19 PM
chevyz71_03
Silverado & Fullsize Pick-ups
July 17th, 2010 11:42 PM
Jeepdude123
December 21st, 2008 6:57 PM
mtbikerjoe17
November 28th, 2006 11:11 AM
Quick Reply: looking for a little more power out of my tbi.
