454 questions
454 questions
AS you see the heads (78 454) have cooling passages front center and back. Why do aftermarket manifolds NOT have these passages,, they seal them off. I have seen some with tapped pipe fittings on the rear that corresponding to the rear passages. Does it not overheat?
Where is the best spot to tap oil pressure port on the block
Thanks,
doug
Thanks,
doug
Thanks,
doug
Thanks,
doug
Troll_in_the_Dungeon
March 9th, 2015 3:00 AM
core shift lsx 454
November 18th, 2012 3:35 PM
heavychevy511
Silverado & Fullsize Pick-ups
October 31st, 2012 8:43 PM
woodstockaz
August 15th, 2010 4:08 PM
rogerwood
Computer, Ignition, & Fuel Systems
November 17th, 2006 12:17 AM
