Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
2005 Equinox automatic door locks
Old November 20th, 2011, 11:42 PM
McGirr87's Avatar
Default 2005 Equinox automatic door locks
Just bought a 05 Equinox and was wondering if I can set the automatic door locks to lock at a certain speed rather than as soon as you put it in drive.
Thanks
Old November 21st, 2011, 5:41 PM
EinST's Avatar
Congrats on your purchase. If it can be done, it should be in the owner's manual. If yours didn't come with one, download a soft copy from Chevrolet Owner Manuals - Factory Warranty, features and options, and maintenance explained.
Old November 22nd, 2011, 3:15 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> McGirr87,
Congratulations on your new vehicle! It is possible to program the automatic locks. The process is as follows:
Programmable Automatic Door Locks
With this feature, all the doors will lock as the transaxle is shifted out of PARK (P) if the ignition key is in the run position and all doors are closed. The doors will automatically lock if the vehicle is going faster than 3 mph (5 km/h).
In the following two situations, when a door is opened, all doors will lock again:
• The brake pedal is applied, a door is opened and then closed, and the brake pedal is released.
• A door is opened and closed without the brake pedal applied while the vehicle is moving faster than 3 mph (5 km/h).
The programmable unlocking feature can be programmed on or off by turning the ignition key to RUN and pressing the unlock power door lock switch for eight seconds. The horn will chirp once when this feature is on and will chirp twice when it is off.
When programmed, all doors will unlock when the transaxle is shifted into PARK (P).
For your reference, these instructions are located in your Owner's Manual on page 2-7. A digital copy of the manual is located at: http://www.extendedgmwarranty.com/ow...et-Equinox.pdf
Best of luck! I hope this was helpful. If you have any further questions, please feel free to contact me.
Louis
GM Customer Service
Old July 9th, 2012, 3:26 PM
netmessys's Avatar
Louis
GM Customer Service
Dummy question, I do have the same Equinox, i dont like when I put the transmition on park on any ligths, or quick stop and all the locks gets open automatic... can that be changed? can be ramind locks ?
Thks
nanamic57
May 21st, 2014 5:22 AM
millerlls220
Equinox
October 15th, 2013 7:33 PM
tephillips
March 19th, 2013 1:41 PM
Jackalope
Silverado & Fullsize Pick-ups
September 4th, 2012 11:24 PM
parkisaac
Traverse
May 7th, 2010 5:29 PM
Quick Reply: 2005 Equinox automatic door locks
