Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
2007 Equinox Stereo Wiring Diagram
Old October 5th, 2010, 5:10 PM
  #21
jimmer3434's Avatar
Hey Charlie or Shawnvw, I have a 2010 Traverse LT and I added a amp in my Travy and I have amplified all the chime and turn signal click. Do you know what wiring carries these signalsor how to adjust them if any? Also would one of you have the 14 and 16 pin diagram for this car, it does not have Bose Or Nav
Scotts500kF150 (September 11th, 2021)
Old July 18th, 2014, 3:46 PM
  #22
normy41's Avatar
Can someone please give or get me the wiring schematics for the stereo in my 2007 Chevy Silverado LT 2500 Duramax. Thank you!
Old December 27th, 2020, 6:04 PM
  #23
Amari Joseph's Avatar
Default Battery Positive Voltage
Originally Posted by charlie pachanga
Radio C1
Connector Part Information
•OEM: 7283-4490-30
•Service: 88988743
•Description: 14-Way F (BK)
Terminal Part Information
•Pins: 1, 8
•Terminal/Tray: 12191812/19
•Core/Insulation Crimp: C/A
•Release Tool/Test Probe: 15315247/J-35616-2A (GY)
•Pins: 2, 3, 9, 10, 4, 5, 6, 6, 7, 13
•Terminal/Tray: 7116-4618-02/14
•Core/Insulation Crimp: Pins 2, 3, 9, 10 - See Terminal Repair Kit
•Core/Insulation Crimp: Pins 4, 5, 6, 6, 7, 13 - P/P
•Release Tool/Test Probe: J-38125-215/J-35616-64B (L-BU)
Radio C1 Pin
Wire Color
Circuit No.
Function
RD/WH
2040
TN
201
Left Front Speaker Output (+)
TN
1875
Right Front Speaker Output (+)
YE
7145
Communication Box Mic Output (+) Signal (UE1 w/U3U)
D-GN
7149
Communication Box Mic Output (-) Signal (UE1 w/U3U)
WH
1487
Amplifier Enable Signal
PU/WH
1382
LED Dimming Signal
BK/WH
1551
Ground
GY
118
Left Front Speaker Output (-)
10
TN/WH
1985
Right Front Speaker Output (-)
11-12
Not Used
13
D-GN
5060
Low Speed GMLAN Serial Data
14
Not Used
whats the difference between the battery positive voltage for the RED WHITE wire and a yellow 12 volt constant wire for an aftermarket radio? Can I just connect the two?
Old December 28th, 2020, 7:33 PM
  #24
ruley73's Avatar
There is no difference. If you're using an adapter harness like you should, the two wires should go to each other when you connect the adapter harness to the factory plug. The factory radio is commanded on/off with a data connection to the BCM so you'll need an interface that converts that data signal to a switched +12v accessory signal that the aftermarket radio can use. The newer GM factory radios doesn't use a switched accessory wire like the older cars used have.
Old March 2nd, 2021, 8:53 PM
  #25
Grim odin's Avatar
Default Help
My brother and law and I were putting in a new stereo in my 07 equinox and he cut off the factory clips to a unusable length will a metra 71-2105 replacement work to fix this or do I need to go to. Get this fixed
Old March 3rd, 2021, 3:58 PM
  #26
ruley73's Avatar
Yes, according to Metra's website, that is the correct harness.
tranceport185
Equinox
August 19th, 2023 11:04 AM
sleseman
1988 - 1998 (GMT400)
October 12th, 2020 10:27 PM
HPDave
April 26th, 2016 12:31 AM
bigbandwith
January 16th, 2011 9:14 PM
UlexiteCavalier
February 16th, 2009 8:56 AM
Quick Reply: 2007 Equinox Stereo Wiring Diagram
