2008 Chevy Equinox Chimes, speakers & navigation sound all gone at same time
The front door, driver's side speakers went out, as did the blinker chimes and seatbelt notification chime and (factory install) navigation voice all went out at same time? Checked fuses, they all look fine?
Official GM Rep
Chevryowner218,
I am sorry to hear that you’re experiencing this issue with your Equinox. Have you spoken with your dealership to confirm the issue?
Thank you
Elizabeth, Chevrolet Customer Service
Thank you
If you live near an Autozone or Advance Auto Parts, take it there and ask them to read the codes for you. Once you get the numbers, ask them what they mean. If you don't ask, they won't tell you what you need to do. Did you check both fuse boxes? My 07 has one under the hood and one on the passenger side of the console.
The front door, driver's side speakers went out, as did the blinker chimes and seatbelt notification chime and (factory install) navigation voice all went out at same time, Checked fuses, replaced speaker with another factory speaker traced wires looked under hood even pulled radio to make sure all the connectors were cleaned and making contact. anyone now what it be as i am having issue with my 08 equinox???????
thank you but the wires are fine talked to dealership the told me to trace the onstar wires as they do run through that side of the speaker system if that is teh case then i ll post it on here and let you know
I regret to inform you that what the dealership told you is incorrect. The only wires that go to the front left speaker come directly from the radio. Onstar and the BCM interface/communicate with the radio, and the radio then outputs the sounds to the front left speaker as necessary. This is why a separate interface is required to keep Onstar & warning sounds/chimes when you replace the factory radio with an aftermarket one. If things were wired as the dealership told you, such an interface would not be necessary.
+1 for the door jam wiring. Its a common problem. Open the door and pull the rubber loom to one side. There will be a wack of broken wires. Sad that a dealer tech could not find that.
if anyone has a early model nox. pull back the loom and wrap the harness with electrical tape to reinforce them before they break.
