Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
2006 Equinox LT AC keeps freezing up
Old September 17th, 2010, 1:51 PM
Otown's Avatar
Default 2006 Equinox LT AC keeps freezing up
In my Equinox, my AC will freeze up so to speak. I will have it running and its blowing ice cold air, then the air slows down almost to a stop. I turn off the AC switch and then in a few minutes the fans is back blowing full force. I switch the AC back on...then repeat after about of 20 min of driving. Can someone point me in the direction to get this fixed? Thanks.
Nick
Old November 1st, 2011, 11:46 AM
bailey33647's Avatar
My Ac is doing this same thing...did you ever figure out what the problem was?
Old November 1st, 2011, 1:24 PM
kevinkpk's Avatar
Check the freon.
Old November 8th, 2011, 4:48 PM
BW56's Avatar
"I turn off the AC switch and then in a few minutes the fans is back blowing full force" Sounds like condensation freezing on your condenser(?) coil I have seen "snow" coming out the air outlets on a few cars in times of high humidity even here in Az. My AC cycles on and off automatically to let the fan defrost the coils like you are doing manually. You might also check the drain hole/tube when you do a defrost. Should get a puddle under your car.
camperbc
December 31st, 2013 5:22 PM
hfd11
Silverado & Fullsize Pick-ups
June 15th, 2013 5:17 PM
w002mia
March 27th, 2013 10:28 PM
TheBlueberry
December 18th, 2010 9:44 AM
Otown
September 22nd, 2010 2:30 PM
Quick Reply: 2006 Equinox LT AC keeps freezing up
