ABS/TRAC related to EGR
#11
OK, so transmission came out of whatever it was doing.Drove my car thought town today and stabilitrak light came on. Hasn't came on since we repaired if and cleared codes until today. Got codes p0404 and c0561. Cleaned the tube at the same time we replaced egr valve. I am baffled as to what is causing this issue. Not sure if I need a new wiring harness or just replace tube all together. Tube wasn't dirty at all when we took it off. Maybe a crack could be the cause too. Transmission is acting up a little bit again. UGH!
#12
Again, pending/intermittent powertrain (Pxxxx) codes do not cause the Check Engine Light to illuminate. P0404 refers to an electrical issue with the EGR valve so the tube is fine. C0561 is just the specific code that is stored whenever Stabilitrak is disabled (by the computer) for whatever reason.
I haven't had the chance to inspect our Equinox for this same issue yet.
#13
I am not sure if they were pending or intermittent. we are thinking it might have to do with the wiring harness. Found a nice page to help us diagnosis the EGR valve issue. Here is the link if you are interested.http://easyautodiagnostics.com/gm/3.1L-3.4L/egr-valve-diagnostic-tests-1.
I'll let you know what we find out and could you let us know what you find out also. Thank you.
#14
So, had a mechanic look at my vehicle. He thinks it might have needed a tune up. He said EGR valve working fine. Did tune up and light still coming on. I'm thinking the next thing we are going to try is the wheel sensor. This is p!ssing me off! If nothing else, I am just going to have to take to dealer. I hate that thought but don't have the $8,000 scan tool they do and I'm sure they are better diagnosing Chevys.
#15
Official GM Rep
If you need any additional assistance into the dealership, please feel free to send a private message to us. We would be happy to look into this further, and get in touch with your dealership on your behalf.
Patsy G
Chevrolet Customer Care
#16
I'm out of dealer warranty and my warranty is limited. I have read a few different things it could be and I just don't know where to start. Could be bad tires, low brake fluid, or wheel speed sensors. Just worried that I am going to have to keep returning to the dealer and still not have the vehicle fixed. I have read that has happened to a lot of people.
Deteoni
March 28th, 2009 1:39 PM
