Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
EQUINOX POWER STEERING
Old June 30th, 2011, 1:19 PM
  #11
suavess's Avatar
Default loss of power steering
Originally Posted by Equinox Owner
I know this post is old but if you know of a person who needs EPS 80 Amp Fuse, I got a couple - I had to purchase several of them from the company since the dealership could not get me the product.
I may need one of these so I will check with you tomorrow. Thanks.
suavess
Old September 17th, 2012, 9:02 AM
  #12
New User
Awaiting E-mail Confirmation
Teadubb's Avatar
Default help!!!!!!!!!!!
Originally Posted by soulmates41681
on my wife's equinox the motor to the power stearing stopped working right after she had to get it jump started. I was wondering if there is some sort of reset to it? Kinda hope it does'nt have to go back to the shop again.
did you find a solution to your problem. I gave a young lady a jump and afterwards my powersteering started
Old February 16th, 2014, 3:27 PM
  #13
ywashin's Avatar
Default 09 Equinox electronic steering whine
Hi,
Recently my 09 Equi Sport has a whine when I turn the steering wheel. Any ideas before I begin to research problem?
Thanks in advance.
Old February 16th, 2014, 9:43 PM
  #14
ruley73's Avatar
Originally Posted by ywashin
Hi,
Thanks in advance.
Possibly a worn alternator. The electric power steering used on many newer GM vehicles (including the Equinox) essentially consists of an electric motor attached to the steering column that helps the driver turn the steering wheel. This motor draws a lot of power, so a worn alternator may whine a bit at idle (when the alternator is least efficient) due to the somewhat high electrical load.
Old February 21st, 2014, 12:36 PM
  #15
ywashin's Avatar
Thanks ruley73!
Old July 5th, 2015, 9:50 AM
  #16
snakbar50's Avatar
Any one knows if the power steering on a 2011 Equinox stops working, what needs replacement? Fuse / relay?
Old July 5th, 2015, 4:29 PM
  #17
ruley73's Avatar
Do you have the 2.4L 4-cylinder engine (has electric power steering) or the 3.0L V6 engine (has hydraulic power steering)?
Old July 5th, 2015, 5:10 PM
  #18
snakbar50's Avatar
It's 2.4L, 4 Cylinder
Old July 5th, 2015, 5:11 PM
  #19
snakbar50's Avatar
it's 2.4L 4 cylinder
Old July 5th, 2015, 10:06 PM
  #20
ruley73's Avatar
There is a large 80A fuse in the underhood fuse block that only goes to the power steering control module (PSCM). If there is a power steering malfunction detected you'll see the SERVICE POWER STEERING message appear. If the fuse looks fine when you check it you'll need to take your Equinox to a dealership or a shop with a good scanner to retrieve troublecodes for a proper diagnosis.
Quick Reply: EQUINOX POWER STEERING
