Headlight Adjustment Equinox - Page 2 - Chevrolet Forum - Chevy Enthusiasts Forums
Michael Lorraine's Avatar
February 23rd, 2011, 5:11 PM   #11
Thanks again for the help and information. Now that I know where and what it is I can access the adjustment wheel without having to remove anything, although I may have to loosen and re tighten the wheel after the adjustment is made and there is access for that as well.
RRRyan_01's Avatar
April 13th, 2011, 6:59 PM   #12
New here, but great info. We just got a great deal on an '08 Sport. All was well until we drove it at night. SO I had my wife drive behind me and I was nearly blinded. Couldn't figure out the adjusters that I stumbled in here. After you look, its obvious, but until you know where to look its impossible.
Thanks!!!
ralenzen's Avatar
May 9th, 2011, 10:02 PM   #13
Thanks for all the info,ralenzen
silverequinox's Avatar
June 11th, 2011, 11:06 PM   #14
Thanks for the info, I replaced my headlights and needed the adjustment!! BTW this SUV has a lot of design issues!!! Removing (well almost) the front grill to change the headlights, the cup holder in the way of the emergency brake handle, a riveted pcv valve. What else????
Chuzz's Avatar
New Johnsonville, TN
June 12th, 2011, 8:45 AM   #15
The only bulb you can change without pulling the headlight assembly is the small amber colored one on top. And it's kind of a pain in the butt too. I kept the old, leaky headlight I had to replace on mine. I'll look at it later and study the adjustment screws. I haven't driven mine after dark yet to know if I need to adjust the new one or not.
Chuzz's Avatar
June 14th, 2011, 10:35 PM   #16
I have to agree with you, silverequinox. What were the design engineers thinking, or smoking would be a better question? I managed to adjust my headlights, but could not do it with a #2 Phillips head screwdriver. I had to remove the four 10mm grille bolts along with the four plastic push pins in the grille and then was able to get a 1/4" wrench with a 10mm socket on the adjuster and get it done. This took me about a half hour to do from start to finish. They may need tweaking a little more, but now that I know what to do , it shouldn't be such a pain in the butt. What a crappy design!!
Mynox's Avatar
Newmarket Ontario Canada
October 6th, 2011, 3:57 PM   #17
I had been trying for 3 years to find out how to adjust the headlights. Thanks very much.
The adjusting screws turned very easily, is that normal or should I tighten them up with the bolt head??? Thanks
mswerb's Avatar
Cleveland, Ohio
October 12th, 2011, 9:50 PM   #18
I actually called my local dealership with questions on how to align my headlights. The service department handed me over to the body shop who told me that there was a screw accessable from the top of the headlight. So glad I found this forum.
Mary Heermans's Avatar
October 13th, 2011, 8:05 AM   #19
Hi Ruley
Does this headlight adjustment also work on a 2008 Chevy Equinox?
ruley73's Avatar
October 13th, 2011, 11:05 PM   #20
Posted By: Mary Heermans Hi Ruley
Yes, it works for all 2005-2009 Chevy Equinox. The Pontiac Torrent probably is the same too.
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
