Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
PCV valve replace
Old August 10th, 2009, 4:51 PM
nf123's Avatar
Default PCV valve replace
How do you replace PCV valve? There is a bracket riveted onto rocker cover holding the PCV valve.
Old December 31st, 2009, 3:35 PM
scouter666's Avatar
They dont want you to replace it. If you have a battery operated dremal tool put a small cutting blade on it and cut the bracket so you can swivel the two parts away. you then pull the pvc valve out and put the new one in. Then you swivel the bracket back into place to hold the pcv valve in. It worked for me and it took about 5 mins to do the cutting. A new pcv is about 5 dollars at the partsource store (Canada). Total time to change the pcv when all is said and done about 15 mins.
Old August 11th, 2013, 11:35 AM
kmich's Avatar
I replaced mine today.
Took a 2 dollar part, and a drill bit in the Cordless Dewalt to break out the rivets. I see no reason why you would pull the valve cover for this job.
Old November 10th, 2020, 5:45 PM
JohnM12's Avatar
Default Complete waste of time and a little money.
Thankfully I bought a cheap valve cover from RockAuto. The supposed PCV valve built into the valve cover, is only a ported hole. If it were ever to get clogged just take off the rubber hose and spray carb cleaner in there. Unlike traditional PCV valves there is no bearing no spring it is just a port. With pliers and some Force you can pull this 'valve' out, advance Auto has a replacement, whole lot cheaper than replacing the whole valve cover.
While in there I looked at my spark plugs number one seem to be a bit dirty.
JohnM12
2007 - 2013 (GMT900)
November 11th, 2020 11:32 AM
TahoeMatt
February 28th, 2013 8:13 PM
jft7032
December 31st, 2011 8:43 AM
brandon_l1000
Silverado & Fullsize Pick-ups
October 30th, 2011 10:24 PM
karaoke04
February 16th, 2007 12:53 AM
Quick Reply: PCV valve replace
