Equinox This SUV offers a smaller, sportier stance than the Trailblazer, all without compromising the SUV abilities.
Chevrolet Equinox
Platform: Theta
powertrain warranty ?
Old October 22nd, 2010, 2:43 PM
mjnp06's Avatar
Default powertrain warranty ?
i have a 2008 equinox with 50k mi. it developed a miss in the engine around 50 mph so i took it to the dealership. they put it on the computer and said it was a couple of bad plug wires. no problem, then they said it would be between $100-$200 to fix it. shouldnt this be covered under the powertrain warranty?
thanks
mike
Old October 22nd, 2010, 5:09 PM
Well they make it real clear on the 2010's it's not covered but not so much on the before 2010....
The Best Coverage in America
Chevy 100,000 mile/5-year transferable Powertrain Limited Warranty with no deductible*
Chevy 100,000 mile/5-year 24/7 Roadside Assistance Program*
Chevy 100,000 mile/5-year 24/7 Courtesy Transportation Program*
Covered for 100,000 Miles/5 years*
Chevrolet will warrant each 2007 through 2010 model year Chevrolet passenger car, light-duty truck, crossover or van for 100,000 miles/160,000 kilometers or 5 years (whichever comes first; see dealer for details) with no deductible, from the original in-service date of the vehicle, for warrantable repairs that are required as a result of defects due to material and/or workmanship to the powertrain components as listed below:
Engine
Cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers valve covers, oil pan, seals, gaskets, turbocharger, supercharger and all internal lubricated parts as well as manifolds, flywheel, water pump, harmonic balancer and engine mount. Timing belts are covered until the first scheduled maintenance interval.
Engine: 2010 Chevrolet vehicles
All internally lubricated parts, engine oil cooling hoses, lines and radiators. Also included are all actuators and electrical components internal to the engine (i.e., Active Fuel Management Valve Lifter Oil Manifold, etc.), cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, manifolds, flywheel, water pump, harmonic balancer, engine mount, starter motor, turbocharger and supercharger. Timing belts are covered until the first scheduled maintenance interval. Exclusions: Excluded from the powertrain coverage are sensors, wiring, connectors, engine radiator, coolant hoses, coolant and heater core. Coverage on the engine cooling system begins at the inlet to the water pump and ends with the thermostat housing and/or outlet that attaches to the return hose. Also excluded are the entire pressurized fuel system (in-tank fuel pump, pressure lines, fuel rail(s), regulator, injectors and return line) as well as the Engine/Powertrain Control Module and/or module programming.
Transmission/Transaxle/Transfer Case
Case, all internal lubricated parts, torque converter, transfer case, transmission/transaxle mounts, transmission/transaxle mounts, seals and gaskets.
Transmission/Transaxle: 2010 Chevrolet vehicles
All internally lubricated parts, case, torque converter, mounts, seals and gaskets as well as any electrical components internal to the transmission/transaxle. Also covered are any actuators directly connected to the transmission (slave cylinder, etc.). Exclusions: Excluded from the powertrain coverage are transmission cooling lines, hoses, radiator, sensors, wiring and electrical connectors. Also excluded are clutch and pressure plate as well as any Transmission Control Module and/or module programming.
Transfer Case: 2010 Chevrolet vehicles
All internally lubricated parts, case, mounts, seals and gaskets as well as any electrical components internal to the transfer case. Also covered are any actuators directly connected to the transfer case as well as encoder motor. Exclusions: Excluded from the powertrain coverage are transfer case cooling lines, hoses, radiator, sensors, wiring and electrical connectors as well as the transfer case control module and/or module programming.
Drive Systems
All internally lubricated parts, final-drive housings, axle shafts and bearings, constant velocity joints, propeller shafts and universal joints. All mounts, supports, seals and gaskets as well as any electrical components internal to the drive axle. Also covered are any actuators directly connected to the drive axle (i.e., front differential actuator, etc). Exclusions: Excluded from the powertrain coverage are all wheel bearings, drive wheel front and rear hub bearings, locking hubs, drive system cooling, lines, hoses, radiator, sensors, wiring and electrical connectors related to drive systems as well as any drive system control module and/or module programming.
During the warranty coverage period, this Chevrolet program provides alternate transportation and/or reimbursement of certain transportation expenses under the Courtesy Transportation Program if your vehicle requires warranty repairs. Several transportation options are available. Refer to your Owner's Manual for details, including reservation of rights, or consult your dealer/retailer.
Chevrolet is proud to offer the response, security and convenience of the 24-Hour Roadside Assistance Program for a period of 5 years or 100,000 miles/160,000 kilometers, whichever comes first. The program provides you with the following services during the New Vehicle Limited Warranty period:
Emergency Towing (to closest Chevy dealer from a legal roadway)
Lockout Service (keys locked inside vehicle)
Flat Tire Changes (spare installed)
Fuel Delivery ($5 worth of fuel delivered on the road)
Jump-Starts (at home or on the road)
Refer to your Owner's Manual for details, including reservation of rights, or consult your dealer/retailer. For specific terms and conditions, please contact your Chevrolet Roadside Assistance Program advisor at 1-800-243-8872.
What Is Not Covered
All the above items are not covered for damage due to accident, misuse, alteration, insufficient or improper maintenance, contaminated or poor quality fuel. Medium-duty trucks, including the C4500, are excluded from this powertrain coverage. For complete details, refer to your Warranty and Owner Assistance Information booklet.
This is a supplement to the express conditions and warranties described in the Warranty and Owner Assistance Information booklet. Other coverages are not extended or altered due to this supplement.
For 2007 through 2009 model year passenger car, light-duty truck, crossover and van owners requiring a more comprehensive coverage than what is provided with this warranty and the New Vehicle Limited Warranty, an authorized GM service contract (GM Protection Plan) is available through your dealer/retailer). This is the only plan recommended by General Motors. See your dealer/retailer for details.
Covered for 3 years/36,000 miles*
Chevrolet backs your new vehicle with its no-deductible, Bumper-to-Bumper New Vehicle Limited Warranty. The entire vehicle is warranted for repairs, including parts and labor, to correct problems in materials or workmanship, for three years or 36,000 miles, whichever comes first (except normal maintenance). The warranty covers towing to the nearest Chevrolet dealership, and there is no deductible for warranty repairs during the warranty period. The warranty transfers automatically with vehicle ownership during the warranty period.
Covered for 6 years/100,000 miles
Corrosion Protection
Chevrolet vehicles are designed and built to resist corrosion. All body and sheet metal components are warranted against rust-through corrosion for six years or 100,000 miles, whichever comes first. Application of additional rust-inhibiting materials is not required under the corrosion coverage and none is recommended. See your Chevrolet dealer for terms of this limited warranty.
An Important Note about Alterations and Warranties
Installations or alterations to the original equipment vehicle (or chassis) as distributed by General Motors are not covered by the General Motors New Vehicle Limited Warranty. The special body company, assembler, equipment installer or upfitter is solely responsible for warranties on the body or equipment and any alterations (or any effect of the alterations) to any of the parts, components, systems, or assemblies installed by GM. General Motors is not responsible for the safety or quality of design features, materials or workmanship of any alterations by such suppliers.
Tycod
July 24th, 2014 12:28 PM
mistyweiss
Cobalt
November 26th, 2013 12:33 PM
Karina152
December 19th, 2010 6:06 AM
07tahoe
September 8th, 2006 4:30 PM
Quick Reply: powertrain warranty ?
