04 electrical relay
04 electrical relay
The key was left on in my express conversion van overnight;
Now my battery seems to be bad, as it won't keep a charge for a couple days (less than 1 year old AC Delco)
GM warrantied!
Hooking up new battery, I hear a click.
Battery cables give a pretty good arc.
I have a "pretty good" draw!
What are the 2 relay's under my drivers side front seat along the frame rail powering. Its one of those that is pulling as I hook up the cable, i'd bet the coil is killing my battery.
Thank you in advance!
-M
GM warrantied!
-M
Whatever those relays are, I don't think it's them...
I've got power all over in my under hood fuse panel with key out, and after cycling the doors. Cycling the ignition triggers fuel pump, dash lights, etc normally, but key off i've got 1.7 amps of unknown draw...
Ideas? Thankyou.
Ideas? Thankyou.
Magnus Sweden
February 20th, 2011 10:29 AM
