1994 g30 (roadtrek) heater control valve
Old September 10th, 2013, 3:43 PM
rickomo1's Avatar
Question 1994 g30 (roadtrek) heater control valve
I have a 1995 roadtrek rv which is a 1994 g30 conversion. My heater control valve is leaking which is simple replace it replace it right??? well in looking up the valve there are two one for regular and one for a g30 with a recreational package. so what is the recreational package ???? my van has both valves in it but the vacuum line to the valve for the recreational package is not connected. The local dealership says they dont know what a recreational package is. should this van have both or since the regular heater control valve is only $15 and the recreational is $80 did it get converted. any help would be appreciated i would like to fix it right.
Old September 11th, 2013, 12:02 AM
canucklehead's Avatar
Rear heat maybe? Do you have rear heat?
Old September 11th, 2013, 12:03 PM
rickomo1's Avatar
Smile your half right
Well i pulled the heater control valve that was leaking boy it is a tight fit. In following the heater hoses the second heater control valve is for rear heat, which since it is a conversion van is not there and the hoses run to the passenger front tire well and are caped off. thank you for the reply some times a person needs the input from some one else to see the light.
jbbcd
August 17th, 2015 9:29 PM
Brandon78
July 9th, 2011 10:48 AM
jcnchi
January 14th, 2008 4:45 PM
rdorris84
December 21st, 2007 6:07 AM
craft211
Silverado & Fullsize Pick-ups
January 20th, 2007 3:56 PM
Quick Reply: 1994 g30 (roadtrek) heater control valve
