2001 Chevrolet Express 4.3 Cranks but Won't start
Old January 10th, 2017, 7:45 PM
dvdalx's Avatar
Question 2001 Chevrolet Express 4.3 Cranks but Won't start
I have a 2001 Chevy Express 4.3 which I use for work. I use it everyday. When I wanted to start it this morning it didn't start anymore. It cranks but won't start. I tried with starting fluid and still nothing.
So I started to solve the issue step by step, none of the following helping in any way.
1. Jump start
2. Checked fuel pressure ( was over 60 - which I think is good). New fuel pump and fuel filter were installed about 10 days ago.
3. I replaced the distributor cap.
4. Checked all sparks to see if they spark and they do.
I don't think the problem would be from PassLock Activation since the "Security" light turns off couple seconds after I turn my key.
What else can it be? Everything was working fine until this morning.
Also I forgot to mention that my CEL is on and the only code it shows is P0430. I don't think it's related to my existing problem.
A friend told me that it might be the EGR valve. Is that possible?
Looking forward to your advice.
Last edited by dvdalx; January 10th, 2017 at 7:48 PM. Reason: I forgot to mention a crucial thing
Old January 11th, 2017, 1:23 AM
canucklehead's Avatar
did you pull out a spark plug and check the gap. Worn plugs make for hard cold starting.
Old January 11th, 2017, 8:00 PM
JIMMYDRIVER1's Avatar
Injection spider might not be working even if you have good fuel pressure.
Old January 11th, 2017, 10:18 PM
Any code relating to the emmisions system can mess your fuel mixture up.
Old January 16th, 2017, 12:33 AM
Artie1's Avatar
EGR valve cannot be a reason for no start. Any emission system code will not be a reason for no start condition either.
If you're saying there is fuel and there is spark, I would check the crankshaft position sensor, it is the main sensor and it will not set the code if it fails. You might want to research how troublesame are they on the 4.3, I heard that on the 8.1L they do fail.
I would also look that sensor's wiring, ideally you would need a oscilloscope for this to look at the signal shape.
Brianwrw
10
December 11th, 2022 1:54 PM
chasecmiller
November 15th, 2022 12:43 AM
JASON EVANS
April 21st, 2019 8:20 PM
grumpymatt
March 31st, 2019 9:33 AM
aric272727
Silverado & Fullsize Pick-ups
February 3rd, 2008 9:57 AM
Quick Reply: 2001 Chevrolet Express 4.3 Cranks but Won't start
