2003 Express Transmission oil Pan Removal
Old July 3rd, 2009, 9:10 PM
xzspk5's Avatar
Default 2003 Express Transmission oil Pan Removal
I am trying to change the transmission fluid and filter on my 2003 Express van, with a 5.3L engine and 4L60-E transmission. However, I cannot remove the transmission oil pan. I have removed the bolts and the shift cable bracket, but the exhast cross pipe runs right under the pan and prevents the pan from lowering down far enough to clear the transmission valve body. Any suggestions on how I can get this removed?
Old July 3rd, 2009, 9:12 PM
suzuki-guy's Avatar
You will have to take the exhaust off!
Old July 4th, 2009, 6:59 AM
Koffietje's Avatar
Yep, as suzuki says. Exhaust needs to be taken of.
WillMatherly88
May 15th, 2015 5:12 AM
gebudjr
Silverado & Fullsize Pick-ups
October 26th, 2010 3:46 PM
tudorstyle
September 17th, 2010 12:26 PM
ukrkoz
February 15th, 2010 7:49 PM
mattwehrwein
February 2nd, 2010 1:29 PM
Quick Reply: 2003 Express Transmission oil Pan Removal
