2006 express/chevy/fourwinds rv as I put gas in the fuel opening the gas comes right
Old December 27th, 2014, 1:52 PM
carillo760's Avatar
Default 2006 express/chevy/fourwinds rv as I put gas in the fuel opening the gas comes right
fuel comes back out as quick as I put gas in
Old December 27th, 2014, 2:18 PM
any dtc's?
possible sources are a blockage in the filler neck vent and fill pipes,
the tank evap vent solenoid is stuck closed, tank vent line is blocked are the canister is blocked.
disconnect the tank vent line to the canister, if the problem is still present, check the filler neck.
DEI
October 25th, 2022 8:59 AM
thompjs
July 6th, 2015 11:18 AM
LeeHamilton
October 26th, 2014 9:49 PM
cheyenne
September 22nd, 2010 2:57 PM
justin2123
July 6th, 2007 7:37 PM
Quick Reply: 2006 express/chevy/fourwinds rv as I put gas in the fuel opening the gas comes right
