6.0L timming marks, help
I have a 2009 gmc van with the 6.0l engine, it broke the cam gear alignment pin and spun the gear. I have replaced the bent vales and have new timming chain and gears but I don't know which mark on the cam gear is the timming mark. any help thanks
Here's a picture. Notice the notch at the bottom on the cam gear and there's a notch at the top on the crankshaft gear. Make sure piston 1 is at TDC before you install. The crank key usually points toward 1 when at TDC.
Last edited by rynmcdonald; November 3rd, 2013 at 9:17 PM. Reason: Additional information.
metalman1232
Silverado & Fullsize Pick-ups
February 24th, 2014 12:16 AM
ALPHADOG707
October 21st, 2013 4:24 PM
ALPHADOG707
Express & G-Series Vans
October 21st, 2013 3:42 PM
