ABS Module
Old January 22nd, 2014, 11:59 AM
straightexhaust's Avatar
Default ABS Module
Hello,
I have a 2007 express 3500. The abs light came on and I have taken it to multiple shops inculding the dealer and they are saying that it needs a new abs module. I was wondering if I can replace this myself or if there is some type of programming or link up to the ecm required or something like that?
Thanks for all of your help
Old January 23rd, 2014, 6:24 PM
canucklehead's Avatar
I would call a dealer and ask a tech. They should be able to explain the procedure, and then you could decide. Remember though, sometimes the part is cheaper if you get it done for you. I ended up only paying 150 bucks labour on a fuel pump job because the difference in part price was way more if I bought it for myself over the counter.
Old January 23rd, 2014, 8:22 PM
if its the module without the modulator valves its a simple bolt up but it may require a scan tool to update the tires size calibration.
pjm333
August 19th, 2015 3:40 PM
skankyfrankie
August 17th, 2009 9:06 AM
eburgher
June 14th, 2008 11:16 PM
Irishlad
April 20th, 2007 10:36 AM
BillV
February 19th, 2006 4:20 PM
Quick Reply: ABS Module
