Tire size
Old April 4th, 2013, 6:57 PM
HOMESLICERYRY's Avatar
Default Tire size
1999 chevy express 1500 4.3, tires on as of now are 225/75/15. The tires I would like to purchase are 235/75/15, will this work? I am buying a heavier load range to handle the weight in the van!
Old April 5th, 2013, 11:43 PM
canucklehead's Avatar
Sure. They are slightly taller, so you will have a longer drive ratio. you will be going a bit faster than the speedo says, and so on.....buts its not a big difference.
Old April 7th, 2013, 4:07 PM
greenfire's Avatar
The size should be fine. But realize the heavier load range will not allow you to carry a heavier load... at least not over the GVW.
Old April 7th, 2013, 6:06 PM
You can still carry your max gvw. It just means that the tranny will work a bit harder with the longer gear range to get going, and the shift points may be a bit off as well.
His difference is 2% larger and well within the max 3% that is recommended.
The 235's will only turn 15 less revs per mile.....
tonymacias
Suspension & Tire
August 21st, 2012 9:50 PM
slammerslugs
Silverado & Fullsize Pick-ups
11
August 12th, 2008 1:48 AM
313hitman
February 4th, 2008 5:01 PM
WOODDOGG
January 29th, 2007 11:17 PM
technoswede
January 3rd, 2007 9:15 PM
Quick Reply: Tire size
