cargo door question
Old November 6th, 2014, 9:54 AM
gene44's Avatar
Default cargo door question
where I work we have a 2008 chevy express 2500 cargo van and on the passenger side cargo door that opens outward the rod that latches the door has come out of the upper bracket and I am just trying to figure out what that fastner is called that would hold that rod into that bracket. It doesn't have a hole in the rod or I would just use a washer and a cotter pin. If anyone knows or can lead me in the right direction I would appreciate it thank you.
Old November 6th, 2014, 11:20 AM
greenfire's Avatar
I don't think the part has a specific name. It is pink in color if I remember correctly and I had to get them at the dealer. Get a bunch of them because you will ruin a few trying to get it attached. I believe the correct way was too attach it to the bracket first and then the rod.
Old November 6th, 2014, 8:48 PM
gene44's Avatar
Makes sense because I was having no luck on finding information on line about what they are called. Thank you.
Old November 12th, 2014, 8:27 AM
tsbrewers's Avatar
dorman makes them, but I don't know off the top of my head the part number. Here is a link to some that MIGHT work, (do your research)
Amazon.com: Dorman 75450 Door Lock Rod Clips, 6 Piece: Automotive Amazon.com: Dorman 75450 Door Lock Rod Clips, 6 Piece: Automotive
arctic_94
July 1st, 2008 9:23 PM
allenh60
February 29th, 2008 2:47 AM
vee
Astro
December 2nd, 2007 1:08 PM
BigRed
October 12th, 2007 1:48 PM
cargosub
July 12th, 2006 3:10 AM
Quick Reply: cargo door question
