Click, tick noise coming from under the hood by the tension pulley
So i recently replaced my water pump, it was a success but now on idle my van has this click/tick noise near the tension pulley...
so i look under the hood...the van is on idle. I hear a click/tick noise once and the tension pulley moves up very little bit, not much but its noticeable...like 10-15 seconds go and it shifts back down....then maybe 30-45 seconds later it does it again...and again.
I drove the van and it seems to drive fine, no loss of power or anything, no check engine or anything
the tension pulley also does play a bit...not too much but it does.
Any ideas or the tick/click noise?
Faulty tension pulley on 2000 Chevy express 1500 5.7? need help - YouTube
here is video of the problem...at the 9 and 18 second mark you can see it shift up a bit...it does it every few seconds, sometimes quickly, sometimes it longer between click/tick
