Crankshaft pulley/ harmonic balancer wobble 2013 Express 2500 4.8l
Old June 8th, 2016, 8:08 PM
Phantoms's Avatar
Default Crankshaft pulley/ harmonic balancer wobble 2013 Express 2500 4.8l
It has a slight wobble which looks very minor in the video, but is more pronounced in person. Although not as bad as others I've seen online. It seems to wobble a little bit front to back as well as side to side.
It has been in a front end collision, but after looking underneath it seems to have been very minor and I don't believe it could have damaged the pulley this far into the engine bay. The van has 130k on it and I am hoping just the pulley needs to be replaced, but worry it could be a more serious issue. The entire unit seems to wobble, not just the part contacting the belts. Is this a usual wear item or a sign of a more serious problem? Thanks in advance.
The engine is pretty loud in the video, so be sure your volume is turned down.
https://www.youtube.com/watch?v=3T13...ature=youtu.be
