Engine control module problem ?
Old Aug 2, 2012 | 11:22 PM
jnaas2's Avatar
Default Engine control module problem ?
found a web site, auto reference center, that tells you how to test the sensors on your vehicle and see if they are working right. The egr solenoid valve was bad, the map sensor was bad, the oxygen sensor was bad and the knock sensor was also bad. But this engine continued to run but the ECM never showed a code. The only thing I can think of that might of happened is the ECM went into limp mode so it could continue to run or the ECM is bad, I have a OBD I, any other thoughts
trappist75
Apr 4, 2022 3:46 PM
pjm333
Aug 19, 2015 3:40 PM
wmc3
Jan 25, 2012 11:40 PM
ragdaddy
Dec 28, 2009 3:40 PM
bisben2
Nov 9, 2006 7:43 PM
