Factory Radio Wire Harness Connector Pinout Explanation
Old June 21st, 2015, 8:23 PM
dberladyn's Avatar
Default Factory Radio Wire Harness Connector Pinout Explanation
I need a place to break down the wiring at each connector in my van. From what I know there can be up to four harness connectors plus antennas, usb, etc. I will edit this until it's done. Feel free to do the same with one post. State your year.
2014 GMC Savana - Options listed in my Garage.
X1 - Connector One
1.) RED/White________ 0340 ___ Battery Positive Voltage
2.) BLUE ____________ 1857 ___ Left Front Speaker Output (+)
3.) ORANGE__________ 1853 ___ Right Front Speaker Output (+)
4.) ***** ___________________ Voice Recognition or Cell Phone Audio Signal
5.) ***** ___________________ Low Reference or Drain Wire
6.) ***** ___________________ Entertainment Remote Enable Signal
7.) YELLOW __________ 6817 ___ LED Backlight Dimming Control
8.) BLACK/White ______ 0351 ___ Main Radio Ground
9.) GREEN ___________ 1957 ___ Left Front Speaker Output (-)
10.) GREY ___________ 1953 ___ Right Front Speaker Output (-)
11.) ***** __________________ May be a Drain Wire
12.) *****
13.) GREEN __________ 5060 ___ Low Speed GMLan Serial Data
14.) *****
X2 - Connector Two
1.) BROWN/White _____ 0367 _ Remote Radio Left Audio Signal (+)
2.) GREEN/White ______ 0368 _ Remote Radio Right Audio Signal (+)
3.) *****___________________ Radio On Signal
4.) *****
5.) TAN _____________ 1859 _ Left Rear Speaker Output (+)
6.) TAN _____________ 1855 _ Right Rear Speaker Output (+)
7.) LightBLUE ________ 0xxx _ Class 2 Serial Data / Cellular Telephone Voice Signal
8.) *****___________________ Cellular Telephone Voice Signal / Amplifier Control
9.) TAN/White ________ 0372 _ Remote Radio Left Audio Signal (-)
10.) GRAY ___________ 0368 _ Remote Radio Right Audio Signal (-)
11.) *****__________________ may be a Drain Wire
12.) *****
13.) WHITE__________ 1959 _ Left Rear Speaker Output (-)
14.) ORANGE ________ 1955 _ Right Rear Speaker Output (-)
15.) BLUE ___________ 0xxx _ Low Reference ????
16.) ***** ________________ may be Battery Positive Voltage ????
So Pins 1&9, 2&10 are the XM Satellite left and right channels. I have no idea of the voltages or the specs. Can these be directly input into an amplifier or?
Pins 7&15 are the mono output of the Onstar Cell... I assume anyways, or is this some form of digitized signal carrying more than just voice? If it is purely audio, is the signal able to be directly input into an amplifier? I just want to grasp the entire GM system.
Is everything controlled through the Low Speed GMLan wire? It would make sense to me if was, I just have no way of personally confirming this.
Attached Thumbnails Factory Radio Wire Harness Connector Pinout Explanation-radio-x1-black-.gif   Factory Radio Wire Harness Connector Pinout Explanation-radio-x2-black-.gif
educk
Equinox
July 21st, 2013 3:03 PM
monkey23
January 3rd, 2013 8:18 PM
monkey23
December 29th, 2012 9:34 AM
guvner
Silverado & Fullsize Pick-ups
January 1st, 2012 3:14 PM
Quick Reply: Factory Radio Wire Harness Connector Pinout Explanation
