Frame mount battery tray
Looking for info on a frame mount battery tray for 2003 express 2500. i did see a post with a GM part number and i looked it up however it appears to be for a conventional sized battery (24, 27, 31 etc).
i would like to install a 4d size battery (2 actually) under the van attached to the frame.
so looking for a frame mount tray/bracket/box/system or w/e that will fit a single 4D battery (ill need 2). id really rather not go with 4 31's even if its possible to buy 4 trays that work.
im looking to relocate house batteries from inside van to outside van. i had been using 4d AGM and would like to use less expensive wet cells but would need to put them outside.
i made a few sketchup designs as having one welded up was what i was planning but i started thinking about schools buses and commercial vehicles with diesels...they must have some factory or upfitter made trays for their large and/or dual battery setups...so i thought maybe someone would know.
this is a legitimate question. i have a unique situation that requires a unique solution. the responses im hoping to get would be educational not entertainment.
and fyi, i have searched the internet and its usual places for what im looking for. is there something wrong with reaching out to a forum such as this for help? how do you think i found this forum to begin with?
