Lower control arm compatibility
Old April 18th, 2016, 1:03 PM
Ferrailleur Dans Le Placard's Avatar
Default Lower control arm compatibility
Hi,
I am looking for a loaded control arm for my GMC G2500 3/4 ton, this is no more available anywhere, so I found the 1 ton available but the shaft is not the same, I am guessing that if the shaft is of the same diameter that mine that could work, I have 1 1/2".
Could you advise?
My shaft looks like that
CONTROL ARM SHAFT NCP 2805537 | NAPA Auto Parts
the control arm that I would like to install is this one:
Amazon.com: Auto Extra Mevotech MS9702 Control Arm and Ball Joint: Automotive Amazon.com: Auto Extra Mevotech MS9702 Control Arm and Ball Joint: Automotive
Thanks.
