Problem with the interior light!!
Hi, when I bought the van, the Inside light was opening when the door open. I was working in the van and the light went off and never open again with the door but if I turn the switch on they open. Someone had this problem before???
Thanks for your help!!
the trucks have a dome light off switch that over-rides the on signal. It is a separate switch from the dome on/off switch. It is part of the dimmer control...press the upper tab.
Mine acts goofy too, many times the dome light doesn't work, and many times the radio stays on even after I open a door. Mine is an '06. I haven't had a chance to work it out yet. But I have a feeling they are related to each other.
Hi, thanks everyone for your help. I look everything that you guys told me and nothing.
But I was installing the LED light in the cargo and when I toutch the wiring near the right back light, they open!!!! And now they work fine. The funniest thing is that I was installing those LED light because my dome light was not working, now I have LED light plus my dome!!! I think that I have enough light Inside!!!
Thanks again
Mike
Thanks again
Mike
paulg_ca
Express & G-Series Vans
October 24th, 2014 5:42 PM
beckya99
July 12th, 2011 12:29 PM
