reverse light switch
Just like it says. My shift lever on my 92 vandura was sloppy so I changed a broken lever spring. It's much better but I can still wiggle the lever and make the reverse lights come off and on. I'd like to nail this down but having trouble figuring out where the light switch is located. All I see from the column is a direct cable to the transmission. Would this be in the column itself? I'd like to know if this can be adjusted before I start ripping the column apart. This is a sweet little project I just picked up for the winter. It easily passed a road safety. Had 2 owners and sat for 10 years. The couple are too old to drive anymore. Had to get it!
Thanks. I was thinking the same. I remember years ago inside another column and seeing where a connection was being made switch wise. The neutral switch even has me perplexed even though it works fine. At the tranny it is merely a connection. I see no switches anywhere along the entire cable.
Internal as in the tranny? I wouldn't think so. I thought they were all adjustable. Depending how long and cold the winter is up here in Canada, I might take the steering wheel apart and take a peek inside. Maybe the reverse switch is adjustable too or can be cleaned up to work better.
