Sliding Door Power Lock not working 2006 Chevy Express 3500 V8 6.0 Gas passenger van
Old April 29th, 2011, 2:46 PM
LeeHamilton's Avatar
Question Sliding Door Power Lock not working 2006 Chevy Express 3500 V8 6.0 Gas passenger van
The power door lock on the sliding door of my 2006 Chevy Express 3500 V8 6.0 Gas Passenger Van no longer works. The front doors power locks work ok.
Need to determine how to diagnose this problem: Fuses, relays, actuator, door connections (two contacts), etc.
Old May 2nd, 2011, 1:01 PM
Official GM Rep
LeeHamilton, are you looking to repair the vehicle yourself or would you be willing to have a dealer take a look at the vehicle? Thank you for your time.
Jeff Morris, Chevrolet Customer Service
Old October 26th, 2014, 2:35 PM
Default sliding door solenoid and door handle repair/replace
Looking to do repairs myself. In the mean time, the outside door handle broke off, so have to operate the door from the inside. Then the clip that pulls the rear door lock rod to the rear of the door broke, found replacement at auto shop but it had a tendency to slip, so added a lock nut.
so the question has compounded to how to replace door handle (hopefully from junkyard) and diagnose solenoid.
Old October 26th, 2014, 9:49 PM
canucklehead's Avatar
Door handle should be easy enough to see once you get the panel off.
My slider has a little issue where the plastic button that slides up and down to lock and unlock get kinda stuck on the way up, so when i cycle the lock to lock the van the slider tries to lock, but doesnt. I find that if I press on the door panel it frees it up.
I did some flexing and got it to work. but I have to double check once in a while.
jstchilln
September 3rd, 2020 2:18 PM
reelcharacter
December 6th, 2016 11:11 AM
goyakpacking
May 9th, 2015 7:51 PM
bolens 66
Astro
September 17th, 2013 8:24 AM
karabug27
Uplander
November 16th, 2011 7:56 PM
Quick Reply: Sliding Door Power Lock not working 2006 Chevy Express 3500 V8 6.0 Gas passenger van
