Spark plugs/wire set
Planning on replacing plugs/wires on my 2009 Express 2500 6.0L V8 Mileage: 93,800 and looking for advice on high quality/performance replacements. I'm considering BOSCH 9602 OE Fine Wire Iridium spark plugs. But, what wire set: BOSCH, ACDELCO, UNITED IGNITION WIRE, Other? I have the Melco ignition coil (as opposed to Delphi). My GM shop manual indicates that each one uses a different cable length seal to seal. The current ACDELCO plug wire appears to have a heat shield on the plug end. Does the heat shield come off with the plug wire or is this separate? Does the heat shield help extend plug wire life?
Thanks!
Thanks!
barnesam
December 31st, 2022 2:34 PM
Simplejack
February 7th, 2012 7:28 PM
dbrog28301
Colorado
May 21st, 2007 9:48 PM
