no it is not a squeal,it is a dry,metal on metal high pitch squeaking.when i sparayed the oil it was dead centre of the pulley,on the bolt and washer.i have a power steering pump leaking,so i'm wondering if i'm putting to much load and the crank pulley is slipping on the shaft.i don't know if it has a keyway or not.the idlers are good.very little play and the bearings are perferct.i'm stumped!!!allso have you ever changed the alternator idler.lookin at it it looks like a huge braket with the power steering,alt and a bolt behind the crank pulley.is that right?as we all know it is hard to get a good look under the hood of a van.
