'76 G20 van pinion bolt question
Old June 2nd, 2008, 5:36 PM
Desert Rat's Avatar
Default '76 G20 van pinion bolt question
In the rear end differential the pinion bolt has broken off inside. How do I remove the broken piece? Or should I be looking for a new rear end. According to the parts house, this is a common problem. I have the bolt head with 1/2" of threads. I don't know how much is left in there.
Help!!
Thanks!
I did find a tool, at http://www.etoolcart.com/index.asp?P...mp;ProdID=9442 in case anybody else has this problem.
Anyone have any experience in using this tool?
Old June 3rd, 2008, 9:37 PM
Bo Lee's Avatar
Default RE: '76 G20 van pinion bolt question
Tool works great. I've used it several times on both GM and Ford broken pinion shaft lock bolts.
It says it works in 5 minutes, but your first time using it, allow 15. It's a very simple procedure and saves damage to the carrier, I know I've done it all - torch, hammer, grinder. This tool is awesome!
I got mine at www.fabbriassociates.com, but I checked your link and it is the same tool. Matco and Snap-on also have one but I'm not sure it by Fabbri.
Bo
Old June 3rd, 2008, 10:43 PM
Desert Rat's Avatar
Thank you for the info!!
I bought it on Ebay, cheaper shipping. ;-)
I'll let the SO know about your experience.
Thanks!
Patty
Old June 9th, 2008, 8:16 PM
Desert Rat's Avatar
Default RE: '76 G20 van pinion bolt tool - Bo!
Hi Bo, thank you for all your help. The old broken bolt is out, the new one in, and I will hopefully go get the last smog cert it will ever need this week.
I bow to your mechanical superiority! [sm=hail.gif]
Thank you again!
Stephen & Patty
Old June 9th, 2008, 8:58 PM
Bo Lee's Avatar
Happy to have helped and glad it worked for you! Good luck with the smog.
Thanks for the update, I was wondering how eveything went.
Bo
Nash
October 3rd, 2015 8:15 AM
chucksrt
Engine Building & Overhauling
December 21st, 2010 9:52 AM
Ole' Blue95
December 27th, 2009 1:52 AM
anova2fast4u
January 5th, 2009 5:22 PM
Desert Rat
June 4th, 2008 8:27 PM
Quick Reply: '76 G20 van pinion bolt question
