Turn Signal Flash Fast, Other Side Dim
Old December 13th, 2013, 4:42 PM
kc5uzd's Avatar
Default Turn Signal Flash Fast, Other Side Dim
2002 Express, 12-passenger van, original condition. Engage turn signal and that side will blink very quickly. At the same time, the other side will dimly blink in unison. From the outside, it almost looks like the hazards are on. Sometimes, the gear select indicator light will blink in the opposite. Sometimes, the system seems to work fine, other than the fast blinking condition. Any ideas?
Old December 14th, 2013, 11:20 AM
Usually the fast blinking is an indication of a burnt out bulb. It could also be a bad connection in the socket and not making good contact with the bulb. Loose or broken wires. Look for all of them.
Old December 15th, 2013, 3:25 AM
canucklehead's Avatar
Ditto. The brake filiment is broke off and touching the parking light filiment inside the bulb,,or something like that.
Old December 16th, 2013, 4:46 PM
kc5uzd's Avatar
I did a walk around, all the bulbs seemed to be working. I'll try just replacing all the bulbs & cleaning the sockets while I'm in there. It can't cost that much. Thanks for the tip!!
Old January 22nd, 2014, 5:50 PM
solwav's Avatar
This thread is old I see but thought to write a response anyway.
I recommend checking your body ground, often times when weird
electrical problems arise it a ground issue.
Old January 25th, 2014, 8:00 PM
200OZ's Avatar
The grounds on the Express Vans that come off the battery, go to the block, and have a woven copper strap to the body, go bad in the snow belt. The gauge cluster usually starts tweaking first in my experience. Give that ground a good look if you're still having issues.
davemudra
Equinox
January 27th, 2016 8:21 AM
L1NK1NP4RK
May 19th, 2012 6:49 PM
gabisue11681
August 17th, 2010 7:24 AM
kcw002
March 22nd, 2007 11:41 AM
jogodlew
December 22nd, 2006 8:23 PM
Quick Reply: Turn Signal Flash Fast, Other Side Dim
