Upper Ball Joint grease question
Hi Everyone!
My 1990 Chevy G20 failed inspection because of an upper ball joint. I ended up replacing both sides myself. However, I think I may have messed up the easiest part. Adding grease. I added too much to the passenger side. There is grease that comes out the top of the rubber boot where the clamp (i guess thats what you'd call it) is. The grease doesn't ooze out continually like a puncture would, but it is there. I wiped it, drove it, and some more came out. I was wondering if eventually it would settle down and be ok or do you think I need to replace it.
Thanks and appreciate any responses. It's supposed to be a cold one tomorrow, and I'd like to avoid anything that's unnecessary.
unfortunately, it will always leak grease...continue to grease it at every oil change. do play checks like you would for a normal ball joint to ensure it isn't getting loose.
Ok Thanks!! Will do!! Glad I don't have to replace it. I'm burnt out after getting the old riveted ones loose. A lot easier to replace now, but still didn't want to do it twice. Thanks again.
If you over grease you can burst the boot. If its burst, then it will leak grease more than usual and you will have to lube more often.....
Try waiting till it needs grease, then watch and see how much the boot inflates with grease as you add it until it leaks out.....if it leaks out without inflating much then its bad.
silverado 1500 2001
Silverado & Fullsize Pick-ups
August 25th, 2014 9:08 PM
