Wheel Spacers to my 1984 Chevy Cargo Van
Hello, I have a 1984 Chevy Cargo Van, 125" wheel base and 350ci V8 engine. I think that it is a G20 and 3/4 ton, Am I right?.
Well, I'm looking for wheel spacers, but my wheels are adapted (my vector rims fits to ford, dodge and Chevy) and I need hub centric and double fixation.
What are the specs that I need?
For example, this wheel spacer:<o></o>
Bolt Pattern: 5/127 (5x5")
Center Bore: 78.1 => I think my van is 78.3
Thread: 14x1.5
Spacer Size: 25MM=> I'm looking 1,5"
Can it fits to my van?
Thread: 14x1.5
<o>
</o>
</o>
Do you know where can I buy these parts? I'm looking in eBay but I'm not sure that it will fit my van.
Best regards
Ps: sorry for my English
Try a four wheel drive parts supplier. Off roaders swap wheels around all the time using those - some times simply for a wider stance (for stability on slopes). sometimes for a set of wheels they like.
Hello, thanks for the info. Maybe I didn´t explain correctly, my 15" wheels actually fit my van, but I need wheels spacers with hubcentric because my rims Bolt Pattern is adapted for chevy, ford and dodge...
Did you know if these spacers will fit my van?
Thread: 14x1.5
Thanks
Thread: 14x1.5
Thanks
Sorry I don't know if the particular specs you mention are good for you or not but still offer the same answer - try a 4wd supplier. They will be able to match up exactly what you want.
If you are only looking for wheel adapters many auto parts stores will carry those. I ran GM wheels on an old VW Beetle years ago using adapters.
You can get spacers OR adapters from one bolt pattern to another OR a combination of spacer and adapter.
HTH
HTH
WASP
February 24th, 2013 6:21 PM
cclifford
Express & G-Series Vans
November 5th, 2010 10:42 AM
jrsavoie
September 13th, 2010 8:03 AM
