Where is the horn on my 3500?
My horn is not working on a van I just purchased, even after replacing the relay and checking to make sure all the fuses are good.
I want to check the actual horn itself but I could not find it peering around the engine bay. Can someone tell me where it’s located on my van?
My horn works so I did not look to see how it is mounted. I recall the horns location after changing the upper radiator hose, it is almost directly underneath.
Thanks, my 1999 horns are in the same spot, below driver's side headlight. One bolt and the bracket that holds them on is removed. I found that there was some corrosion (green crap) that was likely causing the issue. I've tried scraping the contacts with a small pick but I need something to clean it even better. Any ideas what I can use?
1978 Chevrolet C10 half ton horn contact/ horn wiringI have a 1978 Chevrolet C10 that it's horn does
isaac_22
Silverado & Fullsize Pick-ups
December 26th, 2007 9:23 PM
zulu
March 28th, 2007 4:58 AM
