03 2500hd with no crank issue
hello all i am a new to the site and am having problems with my 03 2500hd with the 8.1/allison. last week i turned the key and all the lights and guages came on... but wheni proceeded to start the truck i got nothing.. so i crawled underneath and jumped the selenoid and it started right up.. so i took it to my buddies shop and he replaced the starter and selenoid and the starter switch and that did absolutely nothing...
right now i am turning the key on and going under the hood and jumping the starter relay in order to start it..
Does anyone have any ideas
Professional Mechanic
RE: 03 2500hd with no crank issue
Bad or loose battery cable bolts can cause the exact same syptoms as a bad starter. If they are tight remove them from the battery and look at the cable where it touches the battery. Also inspect the threads.
camarozracer8
Silverado & Fullsize Pick-ups
11
February 1st, 2014 8:03 AM
gregh.ny
10
July 22nd, 2009 6:54 AM
