Notices
1963 Chevy C10 Transmission
Old January 8th, 2007, 11:56 PM
mute_voice's Avatar
Default 1963 Chevy C10 Transmission
I have a 1963 Chevy C10 with a 283 Small block. I have a friend with GM 200 Transmission that he took of a 305 motor i am fairly new to car building and was wondering if this would bolt up to my car.I realize that there are some problems with the GM 200 form the research that i have done but the 4 speed manual that i have in there now is geared too low and the original transmission. What would i need to do in order to make this transmission work? Thanks you for you Help
Anthony
Old January 10th, 2007, 2:32 AM
engine2's Avatar
Default RE: 1963 Chevy C10 Transmission
You might get more responses in the "general tech" section or the "other" in past vehicles section. Good Luck.
Old January 16th, 2007, 7:23 PM
buster's Avatar
Keep the 4speed & change the gear ratio in the rear end
The Wiz
May 25th, 2009 12:48 PM
The Wiz
March 27th, 2009 8:17 PM
yubacitychevy
July 22nd, 2007 10:54 AM
mute_voice
January 8th, 2007 11:58 PM
Quick Reply: 1963 Chevy C10 Transmission
