1978 chevy 350 4 bolt main
hi im new here and not to good with trucks, my question is my trucks 350 is the factory stock motor how do i tell if its 1 of those emission controlled blocks? this truck is entirely stock and has a 400 turbo trans in it, its a 3/4 crew cab long bed.
The truck was, in all likelyhood set up for emissions.
What do you know about the truck's prior owner(s)
Are you sure the pump wasn't removed?
In cars, 350L blocks generally are rated for 180 HP, but sometimes they made the intake valves on the engines for trucks a little larger. So it could be closer to 200 HP.
on the fan shroud there should be a label that gives you your engine info. on the top left it might read PVC AIR EGR CAT also if it meets federal smog or CA. smog requirements
good luck
good luck
jessica.david
March 20th, 2015 12:40 AM
blunt91
Silverado & Fullsize Pick-ups
May 13th, 2013 11:25 PM
1978 Chevrolet C10 half ton horn contact/ horn wiringI have a 1978 Chevrolet C10 that it's horn does
isaac_22
December 26th, 2007 9:23 PM
samahi72
Engine Building & Overhauling
May 17th, 2007 1:14 AM
