2002 Chev truck AC....is hot
It seems that my temp switch is stuck on hot. i took out the ac fuse to see if i could get the hotvent airfrom baking me in the texas spring, but nada. it's still hot. i wanted to take off a panel to look behind but not sure which one to destroy first. those clips are nasty when you cant see how they work. should i start with the vaccum lines behind the ac panel or could this be another issue?
Cooking Texas Style
Cooking Texas Style
RE: 2002 Chev truck AC....is hot
well man they done away with vaccum lines for the a/c a long time ago.. sounds like u might have an hvac control module problem. they aren't very hard to replace. just a pop off the bezel around the radio and a few 7mm screws hold it in.
TahoeMatt
October 15th, 2014 4:10 PM
Ronin7709
July 17th, 2013 12:36 PM
bentwrench
August 25th, 2011 5:52 PM
