Notices
2007 Impala Transmission Whine
Old February 7th, 2012, 4:44 AM
Deano849's Avatar
Default 2007 Impala Transmission Whine
I owe a 2007 Impala with 69000 miles. Normally while driving around town there is no transmission whine or problem. But when I have a long deceleration such as coming off an expressway ramp to a complete stop and then accelerating a low level whine occurs in the transmission. It is more prevalent when I shift into 3rd or 2nd descending a steep grade and come to a complete stop at the foot of the hill. NO WHINE while descending but as soon as I accelerate from stop at foot of hill the whine occurs till it shifts into 2nd or 3rd.
Fluid level is correct and appears pink and smells OK.
Old February 7th, 2012, 4:47 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Deano849,
Answered in the Impala thread.
Louis
GM Customer Service
Old September 14th, 2012, 11:24 AM
Chantele Mallett's Avatar
Default 2007 SS Impala
I am also experiencing the same whining with my transmission on all speeds, can you tell me why, my Impala is at 74,000 miles.
Old September 15th, 2012, 5:37 AM
Deano849's Avatar
I siphoned off 7 qts (about 1/2 of all) of transmission fluid and replaced it with new fluid. Noise immediately disappeared and hasn't returned after 7 months and 10000 miles.
Use a small plastic hose in the transmission dip stick port. Or completely change all fluid
by removing pan. Good luck
Old September 17th, 2012, 12:00 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Chantele Mallett,
I am sorry you are experiencing this issue with your Impala vehicle. I encourage you to consult with a certified technician for additional assistance. They should be able to offer additional information after inspecting the vehicle.
Please keep us posted.
Louis
GM Customer Service
Old August 1st, 2016, 10:10 AM
Mike Edwards's Avatar
Default Don't panic...yet
Ok, took me a while,but, the whining noise may be your power steering pump. Try starting car, make fluid lever is good, put in neutral(apply parking brake&#128516,then turn steering wheel all the way right n left, hold for about 5-10 seconds while increasing eng. rpm just a bit. Try it. If that doesn't work, you made need some money to fix the problem, now, you can panic...😄good luck!
reelcharacter
March 30th, 2022 10:35 AM
randyehughes
September 29th, 2019 9:58 PM
Deano849
February 7th, 2012 4:11 PM
windwakerider
April 12th, 2008 11:28 AM
randyehughes
Silverado & Fullsize Pick-ups
June 7th, 2006 5:56 PM
Quick Reply: 2007 Impala Transmission Whine
