305 trouble
305 trouble
I have an 87 monte with a 305 motor (carborated). I was driving it home the other day when it started to run slightly weak and when accelerating from a stop it would start to hesitate a bit. I had to flutter the gaspedel to get it to keep running. After I turned off the car I went tostart it up and it will run for a few seconds and die. If I pump the gas a bunch of times and turn the key it will fire back up for a few seconds and then quit. Anybody have any ideas or a similar issue? At first I thought the accelerator pump went bad in the carb but alsothink it may be a clogged fuel filter, but haven't been able to disconnect the fuel line from the carb to check it yet.
RE: 305 trouble
I'd do the fuel filter, esp. if it hasn't been done in a long time, maybe even a fuel pump. I had a caprice once that fluttered even at a steady pace; did the fuel pump and that was it.
dozer157
Silverado & Fullsize Pick-ups
September 8th, 2009 7:32 PM
