Notices
454 Fuel Pump stays Running!
Old June 5th, 2007, 4:49 PM
GameOva's Avatar
Default 454 Fuel Pump stays Running!
Tried to go out on the lake this morning but couldn't. The fuel pump continuously stays on no matter if the ignition is off or on??? Does anyone know what my problem is? The iginition switch?
[align=center] [/align]
Old June 5th, 2007, 6:49 PM
GameOva's Avatar
Default RE: 454 Fuel Pump stays Running!
NM found out there was a short in the wire running from the Starter Solenoid to the Ignition switch
Old May 19th, 2019, 2:04 PM
ZZBone's Avatar
Default 454 fuel pump stays running!
Thank you newbie here.. I have exact same problem
After changing upgraded spider and upper and lower intake gaskets. 1997 Chevy Silverado 5.7
Thank you
mangomanj
Express & G-Series Vans
August 17th, 2014 9:51 PM
Jaeaey58
June 22nd, 2013 3:49 PM
BRB
Silverado & Fullsize Pick-ups
December 28th, 2012 8:34 PM
heavychevy511
October 31st, 2012 8:43 PM
hunter10220
May 18th, 2011 8:37 PM
Quick Reply: 454 Fuel Pump stays Running!
