92 chev 350 timing - Chevrolet Forum - Chevy Enthusiasts Forums
92 chev 350 timing
deirulz011815's Avatar
May 21st, 2008, 8:05 PM   #1
92 chev 350 timing
I have a 1992 Silverado with 330,000 Kms or 200,000 miles, what degree would you suggest setting the timing at? Advanced or retarded? I don't believe it has been rebuilt and everything is stock. Thanks.
old dog's Avatar
May 21st, 2008, 10:23 PM   #2
RE: 92 chev 350 timing
new or old set for stock speck's
shawnvw's Avatar
Professional Mechanic
May 21st, 2008, 10:33 PM   #3
Mitchell is showing that the timing be set at 0 degrees.
remember to pull the spark timing by-pass connector out before trying to time the engine
May 22nd, 2008, 8:56 PM   #4
Thanks for the info, but,where is the spark timing by-pass connector Located at? I've never even heard of one of these. I sure do miss my old 81 Camaro with a carburetor andzero sensors, so much easier to work on.
shawnvw's Avatar
May 23rd, 2008, 2:00 PM   #5
there should be a 2 wire harness near the distributor. Usually taped to another harness. There is a gray plug in it that should pull out.
With the key off, pull the plug, start the engine, the check engine light should come on, time the engine, turn the key off, replace the connector, and start the engine. Check engine light should be off and it should run good
May 23rd, 2008, 8:37 PM   #6
Thank you, I'll find a timing light and give it a try.
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
