Notices
93 C1500 5.7 TBI issue
Old September 22nd, 2014, 12:13 PM
easy_rider's Avatar
Default 93 C1500 5.7 TBI issue
So we done a tune up on my friends C1500 it has a 5.7 with a TBI. Just redone the distributor cap rotor button spark plugs wires air filter positive battery wire had the alternators bearings replaced new serpentine belt thermostat radiator cap. And it sounds great when revved but when your on the highway it runs good up until you need to pick up speed it just bogs down there is no overdrive at all it just slowly takes its time gaining speed. And if you try to go uphill it looses most of its power and slows down to 45 mph. We are looking into replacing fuel filter too. Any suggestions would be appreciated
Old September 22nd, 2014, 10:29 PM
Rednucleus's Avatar
So are you saying it won't down shift to a lower gear? And did this problem exist prior to the work you did?
Old September 23rd, 2014, 3:38 PM
easy_rider's Avatar
It had that issue long before. The best way I can explain it is if you're driving uphill and you start slow down with your suburban you press the gas and you accelerate nicely because it kicks into overdrive. Sadly it doesn't do that on his truck. you press the gas the RPM's go up and acts like its going to go into overdrive and then it doesn't
Old September 23rd, 2014, 9:49 PM
Rednucleus's Avatar
Sounds like a trans problem (not downshifting), not the engine. Any codes pulled yet?
Old September 24th, 2014, 6:01 AM
easy_rider's Avatar
Haven't been able to yet this year does not have and OBD port on it. And the factory radio display is damaged so we must replace before we can pull them of the display
Old September 24th, 2014, 6:03 AM
easy_rider's Avatar
Hopefully not that but if it is o well. Just frustrating not thaving a passing gear on the highway
Old September 24th, 2014, 10:47 PM
Rednucleus's Avatar
i believe my 93 sub has a port below the steering wheel under my left knee
Old September 29th, 2014, 1:23 PM
easy_rider's Avatar
OK will inspect
easy_rider
September 22nd, 2014 11:36 AM
sirreldar
Silverado & Fullsize Pick-ups
December 30th, 2013 5:48 PM
bodaddy65
April 27th, 2013 11:50 AM
SuncrestSniper
K5 Blazer
September 26th, 2012 7:39 PM
ultra103
September 13th, 2009 8:15 AM
Quick Reply: 93 C1500 5.7 TBI issue
