98 Suburban injector firing problem.
I have a 98 Suburban, 5.7L. The engine starts and dies. Fuel pressure constant at 70 lbs. No trouble codes present. I hooked a node light to the injector harness. When starting the injectors fire normally. I can sustain idle with starter fluid. When sustaining the idle the injectors only fire intermittently. These symptoms cause the vehicle to start and then immediatly die. What could be causing the injectos to stop firing or fire only ittermittently after starting?
RE: 98 Suburban injector firing problem.
Turn they key to the on position....is the security light flashing?If so, leave the key on for another 10mins, untill the light stops flashing. Turn key off, then start engine
I tried that thing with the security system but it's still cutting out. The darn thing wants to run. Anybody know how I can disable the security system so I can eliminate that as the source of the problem?
Kweezy157
March 19th, 2013 11:23 PM
