Notices
99 Tahoe...Starter Going Bad?
Old May 9th, 2007, 10:50 PM
tahoeskibum's Avatar
Default 99 Tahoe...Starter Going Bad?
I've got a 99 Tahoe. This evening I went into a store and when I came out it would not start. All the electronics come on when I turned the key to the "on" position................but when I went to start it............it did nothing.
Tried to jump it next (to see if my battery was fried)................no luck.
Decided it might be the starter................so I had a friend head my way with some tools. I got back in just for kicks and turned the key a few times.
On the third time it started up...............but was a little weak/hesitant..............like the starter wasn't turning the flywheel very strongly.
I drove it straight home and put it on wheel wheel ramps.
I then turned it off and started it up four times in a row with no problems.
Does this sound like my starter is going out? I'm gonna yank it off tomorrow and take it to Napa for a test.
Thanks-
Mark
Old May 12th, 2007, 11:41 AM
engine2's Avatar
Default RE: 99 Tahoe...Starter Going Bad?
I would check all your battery connections to be sure they are tight and clean. Then I would have the starter and battery checked.
P.S. Welcome to chevroletforum.com
bavant
January 16th, 2012 2:12 PM
blaze_32001
September 10th, 2010 9:33 PM
Cheesehead
Silverado & Fullsize Pick-ups
14
September 2nd, 2009 11:18 AM
jacknanticoke
November 26th, 2008 10:35 PM
pettitk
August 4th, 2007 9:03 PM
Quick Reply: 99 Tahoe...Starter Going Bad?
