Notices
ac wiring
Old June 17th, 2008, 5:56 PM
poppa's Avatar
Default ac wiring
Hi all.Anyone know where I can get a wiring diagram for the ac on a 96 Blazer?? Thanks...
Old June 17th, 2008, 8:09 PM
poppa's Avatar
Default RE: ac wiring/clutch
Different question,same subject(have power). Clutch not engaging,suggestions? Can clutch be removed on truck? How? My manual does not show this procedure.
Old June 18th, 2008, 1:22 PM
Banned
shawnvw's Avatar
Try using 2 jumper wires and put one to ground and the other to B+, If the clutch engages, then your looking at a wiring issue. If you say you have power, maybe the ground is bad?
To remove the clutch you remove the nut in the center of the clutch, and using a puller found in an A\C service kit, you just pull the outer part of the clutch off. Then there is a snap ring that holds the magnet in place. the magnet is sometimes a bugger to get off, but if you are replacing it, don't worry about damaging it.
Old June 18th, 2008, 9:12 PM
poppa's Avatar
Thanks for the reply Shawn. Now I need to find a good deal on a compressor. Everything checked ok except for that.
Old June 18th, 2008, 9:27 PM
Banned
shawnvw's Avatar
If its just the clutch you need, you can buy that separatly and will save you huge bucks
Old June 18th, 2008, 9:46 PM
poppa's Avatar
It doesn't look good for just a clutch.There's no nut there (for removing).There's a ,what looks like,a bolt sticking out with threads on the end and it's all rusty.Or shoyld I say remnents of what looks like used to be threads.
Old June 18th, 2008, 10:46 PM
Banned
shawnvw's Avatar
There is supposed to be a nut on that stud. If not, no biggie....the cluch is pressed into place. If you had access to an a\c service kit you could pull it apart....really not hard to do
Old June 19th, 2008, 9:28 AM
poppa's Avatar
Do you know where I could see a pic of the puller? It's not an ac shop but we have a couple different pullers.Thanks Shawn.
Old June 19th, 2008, 4:02 PM
Banned
shawnvw's Avatar
Here is all the tools you might need to do the job
http://www.autozone.com/in_our_store...nditioning.htm
You'll need the hub remover, clutch pulley puller(needed to prevent damage, you don't need to worry about that), and the clutch holder so you can put a nut onto the shaftwhen your done
Old June 20th, 2008, 7:47 AM
poppa's Avatar
Do I need that shaft to put the clutch on?Wondering because that doesn't have very good looking threads.Thanks Shawn.
Quick Reply: ac wiring
